no grid
unktim
no grid
Post by unktim » Fri Jul 18, 2014 2:39 pm
Windows vista, qcad 3.6.2
I can't see the grid. I experienced this with 3.6.0. I updated to 3.6.2 and the problem persists. I make sure that the grid button is activated. There is nothing in help but how to turn it on. unktim
Re: no grid
Post by Clive » Fri Jul 18, 2014 3:49 pm
Hi unktim
It's difficult to know what the problem is without sitting beside you to look at your set up ... so a few questions first.
Do you have the same problem on your Ubuntu set up?
Have you carefully checked Application/Drawing preferences for the Grid set up?
What colour background are you using (Model space back ground colour) ?
What happens when you zoom out or in fully?
unktim
Re: no grid
Post by unktim » Fri Jul 18, 2014 9:13 pm
Do you have the same problem on your Ubuntu set up? Ans: I have never been able to install qcad or any other downloaded package on ubuntu.. I have tried UBU 12.04, 13.10, and 14.04
Have you carefully checked Application/Drawing preferences for the Grid set up? Ans: Yes
What colour background are you using (Model space back ground colour) ? Ans: White
What happens when you zoom out or in fully? Ans: I zoomed the entire spectrum and got nothing but white.
P.S. I bought qcad 3.6.0 and for a few days it worked fine, then, no visible grid. when I got notice that 3.6.2 was available I uninstalled 3.6.0 and installed 3.6.2 thinking that would fix it but the problem persists. unktim
J-J
Re: no grid
Post by J-J » Sat Jul 19, 2014 11:11 am
Hi Unktim,
When you perform an install with an update, the old QCAD.ini is used. To get a fresh start, close QCAD, go and rename your "qcad.ini" file to "qcad.old" for example
C:\Users\your_profile\AppData\Roaming\QCAD\qcad.ini
Then restart QCAD, this will reset some of the default parameter (screen will likely have a black background). See what it does, your setup is preserved in the "old" file, and you can always do a line by line comparison with the newly created "ini" file to track possibles clues.
Good luck
JJ Win7 pro-64
unktim
Re: no grid
Post by unktim » Tue Jul 22, 2014 2:22 pm
Clive,
I received my qcad disc in the mail so I uninstalled everything and installed it from disc. I have my grid back,however I can no longer find the 3.6.2 update.
Re: no grid
Post by Clive » Tue Jul 22, 2014 2:32 pm
Okay, go to main menu > help > Check for QCAD pro updates. You will need to log into your personal customer area and download it.
When you download updates you can save them to a new folder on your desktop.
Let us know how you get on.
unktim
Re: no grid
Post by unktim » Wed Jul 23, 2014 1:15 pm
Clive,
I now have v3.6.2 and a grid. thanks for all. unktim
Re: no grid
Post by Clive » Wed Jul 23, 2014 10:11 pm
Good, glad you are back on track again. It is worth taking note of J-J's advice, this is the correct way to achieve a good install of an update in QCAD.
