.dwg drawing
Esam13
.dwg drawing
Post by Esam13 » Tue Nov 06, 2018 7:15 pm
When I opened an existing .dwg file the drawing is a different scale, ie the line in the orginal file was 23965mm and is now 2396.5mm can I simply resize X 10.
Re: .dwg drawing
Post by andrew » Tue Nov 06, 2018 7:46 pm
QCAD should open the file exactly as it is stored.
For more information, please attach your drawing file, thanks.
Re: .dwg drawing
Post by Husky » Tue Nov 06, 2018 7:46 pm
... can I simply resize X 10.
There are a few possibility's what could cause this issue. Please attache the drawing and give us one example dimension what shows the scale problem. Thanks.
