.dwg drawing
.dwg drawing
When I opened an existing .dwg file the drawing is a different scale, ie the line in the orginal file was 23965mm and is now 2396.5mm can I simply resize X 10.
Re: .dwg drawing
QCAD should open the file exactly as it is stored.
For more information, please attach your drawing file, thanks.
Re: .dwg drawing
There are a few possibility's what could cause this issue. Please attache the drawing and give us one example dimension what shows the scale problem. Thanks.
