Husky wrote:Is there still a way to export/import the QCad files (dxf, dwg) to Sketchup (free edition)? Just to use the 2D drawings as a basic to pep it up to 3D drawings?
clive wrote:No, not any more - you used to be able to but now the 'Free' version is crippled for this!
Husky wrote:I use an other programs for Gears what is able to export in a .dae Format what is then readable by Sketchup 8. It is not a perfect solution but it is a workaround what saves a lot of time.
Would be nice to have something like that for QCad ...![]()
Husky wrote:Why I haven't used the Isometrics function from QCad (which is really good!) .... because from time to time you need more flexibility ....
Done:clive wrote:Maybe you can add a feature request Husky - hint, hint
clive wrote:... which I`m sure would bring in more users to the world of QCAD, people looking for a good 2D to 3D workflow
Return to QCAD 3.0 'How Do I' Questions
Users browsing this forum: No registered users and 1 guest
