Modify - Attribute
Use this forum to ask questions about how to do things in QCAD version 3.1/3.0
Modify - Attribute
Postby andrew » Tue Apr 17, 2012 12:52 pm
From a QCAD user:
I've noticed that the Modify - Attribute tool has disappeared in QCAD version 3. How can I for example move a bunch of objects from one layer to another or change the line type, color or line weight of selected entities?
Re: Modify - Attribute
Postby andrew » Tue Apr 17, 2012 12:55 pm
This functionality has been replaced by extended functionality of the property editor:
1. Make sure the property editor is visible. If not, enable with View - Tool Bars - Property Editor.
2. Select entity(ies) to modify.
3. Change desired properties in property editor.
With the property editor you can not only modify basic attributes such as layer, style and color but also geometrical properties or the content of texts and dimension labels.
Return to QCAD 3.1/3.0 'How Do I' Questions
Who is online
Users browsing this forum: No registered users and 1 guest
