Show a "broken" object length
biomade
Post by biomade » Fri Oct 31, 2014 5:13 pm
working on a drawing and it must fit on 11" x 8" wide paper.
The body of the piece is 2" wide by 2" high by 18" long and all the detail work is at each end so I don't need to show the middle.
How to I draw a break in the middle to indicate that can show that the "middle" is the same and then how do I use the dimension tools reflect the actual length
Thanks in advance to those who help me figure this out.
Re: Show a "broken" object length
Post by andrew » Fri Oct 31, 2014 5:45 pm
The way how you indicate that the part drawn is longer than shown depends largely on industry specific, local or company specific standards.
This is one popular way often used in CAD:
Screen Shot 2014-10-31 at 17.40.55.png (17.9 KiB) Viewed 5200 times
More conventional examples:
https://www.me.utexas.edu/~rbarr/draft/ ... reaks.html
For the dimension(s) that have to show a label that does not equal the measurement, you can override the label using the property editor:
Screen Shot 2014-10-31 at 17.44.19.png (61.21 KiB) Viewed 5200 times
biomade
Post by biomade » Fri Oct 31, 2014 5:53 pm
Is those "lightening" lines just segments or is there a block for this??
Thanks that is what I needed to do!!
Post by andrew » Sat Nov 01, 2014 1:34 pm
biomade wrote:Is those "lightening" lines just segments or is there a block for this??
These can be loose line segments, a polyline or a block, whatever you prefer.
biomade
Post by biomade » Mon Nov 03, 2014 6:12 pm
Thanks, I think I got it now, I went with line segments.
Our work here is done e_surprised
