Scaling from feet and inches to millimeters
scot6puk
Post by scot6puk » Mon Sep 15, 2014 11:10 pm
How do you re-scale a drawing from feet and inches to 7mm to a foot? I am using version 3.6.4 on windows 7?
Len
Re: Scaling from feet and inches to millimeters
Post by Husky » Tue Sep 16, 2014 1:31 am
Hello Len,
do I understand you right?
Your drawing is in foot and you need to change the unit to mm. The current foot has then to be 7 mm in the mm drawing, right?
If I'm right you have to scale it 7 times bigger than now and change then the unit from Foot to mm.
If I'm wrong .... please enlighten me with more specific details. :wink:
