Moving entities to different layer
Please use this forum to post feedback and suggestions related to QCAD Professional 3.0.
Postby philipslack » Fri May 18, 2012 6:26 pm
Just started working with QCAD3.0. In version 2.2 I could move an entity to a different layer by
selecting that line or group of lines and clicking on the layer name in the layer list. Is this not possible
in version 3.0 or is there an option I need to select to "turn this on?"
Thanks,
Phil
philipslack
Re: Moving entities to different layer
Postby andrew » Fri May 18, 2012 7:04 pm
Moving selected entities to a layer by double-clicking the layer will be available in QCAD 3 final again.
For now, you can use the property editor:
- View - Tool Bars - Property Editor
- Select entities
- Change layer property in property editor
Postby clive » Fri May 18, 2012 7:09 pm
philipslack wrote:Just started working with QCAD3.0. In version 2.2 I could move an entity to a different layer by
Thanks,
Phil
Hi Phil
In QCAD 3
Select the entities and from the property editor (main menu > View > Tool bars > property Editor) select the layer you wish to move the entities to move to.
[Sorry Andrew - didn`t realize you posted too!]
move an entity to a new layer.png (49.04 KiB) Viewed 1314 times
clive
Postby philipslack » Fri May 18, 2012 10:13 pm
Thank you both! -Phil
philipslack
Return to QCAD 3.0 Suggestions and Feedback
Who is online
Users browsing this forum: No registered users and 1 guest
cron
