LeoP wrote:What would be really useful is a method to select entities by type, rather than by location or layer.
It could have a user interface like the snap command with buttons for the entity type to select, or like the line command with a drop-down box.
This would enable one to quickly select e.g. all texts in a drawing for subsequent attribute modification. Now one has to select each text individually if the texts are scattered over the drawing and layers...
I agree although this post is over 2 years old its still very much valid - often I am in the same situation.
I have added a feature request for this:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=630One 'workaround' (which you may have found by now
) which Andrew gave me is this:
1. Select everything first (Select All TA).
2. Go to > Property Editor > click on Selection and from the 'drop' down menu select the entity type e.g. Text.
3. Property Editor > layer > then click on the + button (Move Selection to a New Layer), now assign a new layer.
4. Go to new assigned layer and from there edit/modify your entities (in this case text).
As I say you probably know this by now - but its still a useful workaround for now for other users.
