getPosition() for TextEntity showing 0,0,0 [SOLVED]
arun
Post by arun » Mon Dec 11, 2023 3:36 pm
How does the getPosition() work for RTextEntity? I get the result of this as
"RVector(0.000000, 0.000000, 0.000000, 1)"
. However, the Property of this entity shows different values. I have attached the screenshot for reference
Re: getPosition() for TextEntity showing 0,0,0
Post by CVH » Mon Dec 11, 2023 3:57 pm
Try:
https://qcad.org/doc/qcad/3.0/developer ... 1a59df2703
Text position is hardly used, text is aligned to a certain point.
arun
Post by arun » Mon Dec 11, 2023 4:02 pm
Thanks a lot CVH, that was super quick and perfect.
Also, for further understanding, isn't getPosition() not to be used for Text entities? A bit confused on this method
Re: getPosition() for TextEntity showing 0,0,0 [SOLVED]
Post by CVH » Mon Dec 11, 2023 4:11 pm
Probably from before text could be aligned ... Just guessing.
Or it may have a meaning in other applications. :wink:
Won't be the sole confusing bit you might discover.
arun
Post by arun » Mon Dec 11, 2023 5:06 pm
Thanks again CVH
