The instructions you are linking to are unclear: I don't understand how/where to run "configure.exe -platform win32-msvc20XX -[debug|release]". In the QT-source dir there is just a "configure.bat" file, which terminates because "nmake" is obviously missing:
Creating qmake...
execute: File or path is not found (nmake)
Cleaning qmake failed, return code -1
However, I have installed qt previously with "qt-opensource-windows-x86-msvc2013_64-5.5.1.exe"
I can open "qcad.pro" in die QCAD-source-dir with QTCreator and start the compilation (which Fails as stated above).
What's wrong about this way?
yes
