tool: middle of a segment
michel
Post by michel » Mon May 12, 2008 4:23 pm
Hello Andrew,
What do you think about a snap possibility to the middle of a segment?
Michel
ttrw
Post by ttrw » Mon May 19, 2008 8:35 pm
Hi Michel.
Such a tool already exists! Under 'snap', choose 'middle'. (command line; sm).
Hope that helps :)
Tom
Macbook Pro 2.14gHz 10.5.5 (UNIX!)
michel
Post by michel » Wed May 21, 2008 5:50 am
Hello ttrw,
I kbow that the tool you mentioned exists, it gives you the middle of a line. So far it's correct.
But what i meant is a tool which gives you the middle of the segment or segments within a line. As long as you move with the cursor along the line this option should enable to find always the middle of the segment on which you move along.
Michel
Return to “QCAD 2.1/2.2 Suggestions and Feedback”
