3D
stan.distortion
3D
Post by stan.distortion » Fri Apr 04, 2008 1:56 pm
I didn't see it in any of the suggestions post so here goes. Are there any plans for any kind of 3d implementation in qcad?
cheers
stan.distortion
Post by stan.distortion » Fri Apr 04, 2008 2:01 pm
What I was looking for in particular was not a gl type app but a way of being able to specify a height for layers and possibly to be able to use any 2 of 3 axis, to be able to work on X and Z for instance then flip to Y and Z. In my case its for CNC work and if it could be coupled to a g-code generator it would make camexpert a very reasonably priced app in my opinion.
cheers
Post by andrew » Fri Apr 04, 2008 2:18 pm
You might be interested to know that in CAM Expert, you can assign a Z level for each layer during export. This can for example be used to engrave with different cutting depths.
Return to “QCAD 2.1/2.2 Suggestions and Feedback”
