Command Line Shortcuts...
rlhorn
Post by rlhorn » Thu Jul 19, 2007 12:58 pm
Will there be an update any time soon for a fix on the command line shortcuts? Some work, others do not.
WISH LIST ADD: A way to edit the shortcuts for user preferences.
i.e. instead of the "li" for line, the ability to change to "s" for line... etc...
I like to try to keep my shortcuts on the left side of the keyboard.
I would also like to commend you on an excellent product.
michael
Post by michael » Sun Sep 16, 2007 2:55 pm
I think it is good to have all commands always with the same names.
Maybe you can use a external tool, for key recording and setup a hotkey here.
Post by andrew » Mon Sep 17, 2007 9:20 am
Note that a single hotkey like 's' would disable all two letter key codes starting with 's'. Only two letter key codes make it possible to have a key code for every command in QCad.
Return to “QCAD 2.1/2.2 Suggestions and Feedback”
