when I draw a rectangle and try to modify its properties afterwards I have to modify every single line of it. Doing so is pretty time consuming. I would suggest to change this in a way the user only has to change the two points diagonal to each other.
Regards
Jens
An easier way to modify entities (rectangles)
- Newbie Member
- Newbie Member
