Creating splines using dxflib
What are the steps for creating a spline using dxflib? More specifically, when do I define the spline's knots in relation to calling the writeSpline() function?
Eric
Here's a bit of pseudo code that should be helpful:
int numKnots = numControlPoints + splineDegree + 1;
int flags;
if (spine is closed) {
flags = 11;
} else {
flags = 8;
// write spline header:
dxf.writeSpline(
*dw,
DL_SplineData(spline degree (2 or 3),
numKnots,
numControlPoints,
flags),
attributes
// write spline knots:
int k = spline degree + 1;
DL_KnotData kd;
for (int i=1; i<=numKnots; i++) {
if (i<=k) {
kd = DL_KnotData(0.0);
} else if (i<=numKnots-k) {
kd = DL_KnotData(1.0/(numKnots-2*k+1) * (i-k));
} else {
kd = DL_KnotData(1.0);
dxf.writeKnot(*dw, kd);
// write spline control points:
for each control point {
dxf.writeControlPoint(*dw, DL_ControlPointData(x, y));
