Presale Question
- Registered Member
Presale Question
As my user name implies, I am from the era of lead pencils, paper and straight edges. I recently received a complete set of CAD files for house plans. The files are .dwg format. Will this software allow me to upload these files, make modifications to the drawings, save changes in the .dwg format and export to a USB flash drive? Thanks for your help.
Re: Presale Question
Hi LeadOnPaperGuy - welcome to the QCAD forum.
QCAD Features
https://www.qcad.org/en/documentation/features
Yes - you can check mark every point of that requirement if your set of drawings is drawn in 2D. QCAD Pro is built for that task!LeadOnPaperGuy wrote: ↑Thu Apr 06, 2023 6:48 pmWill this software allow me to upload these files, make modifications to the drawings, save changes in the .dwg format and export to a USB flash drive? Thanks for your help.
QCAD Features
