comma as decimal separator in cnc code
Re: comma as decimal separator in cnc code
Makes sense, yes. Update attached.
Changes:
- always prepare for cutting before defining arc center (CC)
Changes:
- Tnc145.js
- (2.76 KiB) Downloaded 1298 times
andrew, it works fine, thank you so much!
first move is executed on Z level 0 but should be Z Clear?
1 TOOL DEF 01 L+ R+0.6
2 TOOL CALL 01 Z S 2000
3 L X+1,272 Y+0,400 R0 F9999 M13
4 L Z-0,300 R0 F30 M
5 L X+0,272 R0 F30 M
6 L Y-0,533 R0 F30 M
7 CC X+0,737 Y-1,136
8 C X+0,806 Y-0,378 DR- R0 F30 M
9 CC X+0,745 Y-1,018
10 C X+1,206 Y-1,467 DR- R0 F30 M
11 CC X+0,777 Y-1,046
12 C X+0,250 Y-1,333 DR- R0 F30 M
13 L Z+1,000 R0 F9999 M13 F30
14 L X-1,350 R0 F9999 M13
15 L Z-0,300 R0 F30 M
16 CC X-0,814 Y-1,027
17 C X-0,817 Y-1,644 DR+ R0 F30 M
18 CC X-0,817 Y-1,122
19 C X-0,817 Y-0,600 DR+ R0 F30 M
20 CC X-0,817 Y-0,078
21 C X-0,817 Y+0,444 DR+ R0 F30 M
22 CC X-0,813 Y-0,139
23 C X-1,350 Y+0,089 DR+ R0 F30 M
24 L Z+1,000 R0 F9999 M30
- K-3353 engraved within 7mm diameter.txt
- (1.69 KiB) Downloaded 1333 times
- K-3353 engrave works fine.JPG (47.29 KiB) Viewed 41354 times
- 35 engrave works fine.JPG (27.18 KiB) Viewed 41356 times
Can you correct the first 4 lines of the program and post them, so I can update the configuration, thanks.peter wrote:our first move seems to be executed on Z level 0 but should be Z Clear?
andrew, I am not shure, it may be perfect as it is, it looks like original TNC145 header syntax, I have to find it out on the machine.
behavior of TNC is perfect with the actual header syntax, moving 3 L X+1,272 Y+0,400 R0 F9999 M13 with holding last Z level, then 4 L Z-0,300 R0 F30 M
to get program input to TNC145 without error. there must be
1 TOOL DEF 01 L+ R+0.6 >>>>>>>>> 1 TOOL DEF 01 L+0 R+0.6 <<<<<<<<<<<<<< L+0
13 L Z+1,000 R0 F9999 M13 F30 >>>>>>>>> 13 L Z+1,000 R0 F9999 M13 <<<<<<<<<<<<<< without F30
OK, great. Thanks for the confirmation.
feedrate is set twice in one line is not perfect at the moment (manually edited with no problem)
OK, update attached.
- Tnc145.js
- (2.79 KiB) Downloaded 1295 times
thank you, I've just checked CAM output file, looks perfect, fine! Machine test result will be posted later, an other question, for output file extension *.cnc instead of *.nc how to manage, please?
Add this to your configuration:peter wrote:an other question, for output file extension *.cnc instead of *.nc how to manage, please?
Tnc145.prototype.getFileExtensions = function() { return ["cnc"]; };
- Tnc145.js
- (2.86 KiB) Downloaded 1279 times
andrew, thank you for your great job, QCADCAM 3.11.0 is fine for me, looks very good in work results!
Good point!
This will be interesting for my TNC 430 to engrave Labels
I try to extend TNC 415 to TNC 430
Extension .cnc to .h no problem!
TrueType etc. is nice with QCad CAM
Normal contours and holes I process with my own software
Is it possible to disable layers, in my case useful for "CAM-Labels" not for the rest! (one complete CAD-file) ?
TOOL CALL with "GRAV" (comes from a Tool table) corrupts the script !
Solution for inserting " ?
is it possible to catch the filename SCHRIFT.DXF or alternativ the name of the Layer to feed the first and last line
to complete the CNC-file?
0 BEGIN PGM SCHRIFT MM
1 TOOL CALL "GRAV" Z S2500
5 CC X+0,000 Y+0,000
6 C X-100,000 Y+0,000 DR+ R0 F30 M
7 CC X+0,000 Y+0,000
8 C X+100,000 Y+0,000 DR+ R0 F30 M
9 L Z+1,000 R0 F9999 M30
10 END PGM SCHRIFT MM
Yes, simply hide those layers in the layer list (eye icon) before exporting to CAM.olly wrote:Is it possible to disable layers, in my case useful for "CAM-Labels" not for the rest! (one complete CAD-file) ?
Quotes have to be escaped in JavaScript strings:olly wrote:TOOL CALL with "GRAV" (comes from a Tool table) corrupts the script !
this.writeLine("TOOL CALL \"GRAV\" Z S2500");
File name of exported file: this.fileNameis it possible to catch the filename SCHRIFT.DXF or alternativ the name of the Layer to feed the first and last line
File name of drawing file: this.document.getFileName()
Layer name of current layer:
var entity = this.getEntity(); var layerId = entity.getLayerId(); var layer = this.document.queryLayer(layerId); var layerName = layer.getName();
Andrew thanks for your hints
one Step is to go
this.writeLine("BEGIN PGM "+this.document.getFileName()+"MM");
here I got NullString
this.writeLine("BEGIN PGM "+this.fileName+"MM");
here the complete path will be returned
OSX 10.11
one Step is to go
OSX 10.11
This would indicate that the drawing has not been saved and therefore does not have a file name.olly wrote:this.writeLine("BEGIN PGM "+this.document.getFileName()+"MM");
Yes. If you need to get the file name only, use new QFileInfo(this.fileName).fileName().this.writeLine("BEGIN PGM "+this.fileName+"MM");
