Getting errors while compiling community edition
Avneet
Post by Avneet » Thu Feb 28, 2013 7:55 am
I am using Ubuntu 12.10 64-bit system.
I want to compile the community edition.
Steps are:
$ export QTDIR=/usr/share/qt4
$ export QMAKESPEC=$QTDIR/mkspecs/linux-g++-64
$ export PATH=${QTDIR}/bin:${PATH}
$ cd dxflib
$ ./configure
$ make
$ sudo make install
$ cd fparser
$ ./configure
$ make
$ sudo make install
$ ./build_qcad.sh no_trans
At this step i am getting errors
sep is /
make[1]: Entering directory `/home/avneet/Desktop/qcad-2.0.5.0-1-community.src/qcadguiqt/src'
make[1]: *** No rule to make target `ui/qg_arcoptions.h'. Stop.
make[1]: Leaving directory `/home/avneet/Desktop/qcad-2.0.5.0-1-community.src/qcadguiqt/src'
make[1]: *** No rule to make target `ui/qg_arctangentialoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_beveloptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_blockdialog.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbar.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbararcs.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbarcircles.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbardim.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbarellipses.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbarinfo.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbarlines.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbarmain.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbarmodify.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbarpoints.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbarselect.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbarsnap.h'. Stop.
make[1]: *** No rule to make target `ui/qg_cadtoolbarsplines.h'. Stop.
make[1]: *** No rule to make target `ui/qg_circleoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_commandwidget.h'. Stop.
make[1]: *** No rule to make target `ui/qg_coordinatewidget.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dimlinearoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dimensionlabeleditor.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dimoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgarc.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgattributes.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgcircle.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgdimension.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgdimlinear.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlghatch.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgimageoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlginitial.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlginsert.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgline.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgellipse.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgmirror.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgmove.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgmoverotate.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgoptionsdrawing.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgoptionsgeneral.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgpoint.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgrotate.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgrotate2.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgscale.h'. Stop.
make[1]: *** No rule to make target `ui/qg_dlgtext.h'. Stop.
make[1]: *** No rule to make target `ui/qg_exitdialog.h'. Stop.
make[1]: *** No rule to make target `ui/qg_imageoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_insertoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_layerdialog.h'. Stop.
make[1]: *** No rule to make target `ui/qg_librarywidget.h'. Stop.
make[1]: *** No rule to make target `ui/qg_lineangleoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_linebisectoroptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_lineoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_lineparalleloptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_lineparallelthroughoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_linepolygon2options.h'. Stop.
make[1]: *** No rule to make target `ui/qg_linepolygonoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_linerelangleoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_mousewidget.h'. Stop.
make[1]: *** No rule to make target `ui/qg_moverotateoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_printpreviewoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_roundoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_selectionwidget.h'. Stop.
make[1]: *** No rule to make target `ui/qg_snapdistoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_textoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_trimamountoptions.h'. Stop.
make[1]: *** No rule to make target `ui/qg_widgetpen.h'. Stop.
-------- Building qcadlib --------
./build_qcad.sh: 211: [: xlinux: unexpected operator
make prepare
make[1]: Entering directory `/home/avneet/Desktop/qcad-2.0.5.0-1-community.src/qcadlib'
test -d ./include || mkdir -p ./include
( cd ./include; rm -f *.h; \
for hf in `find ../src -name '*.h'`; do \
if [ "x$OS" = "xWindows_NT" ]; then \
cp "$hf" .; \
else \
ln -s "$hf" 2> /dev/null; \
fi \
done )
make[1]: Leaving directory `/home/avneet/Desktop/qcad-2.0.5.0-1-community.src/qcadlib'
rm -f ./lib/libqcad.a
make ./lib/libqcad.a
make src/Makefile
make[2]: Entering directory `/home/avneet/Desktop/qcad-2.0.5.0-1-community.src/qcadlib'
make[2]: `src/Makefile' is up to date.
make[2]: Leaving directory `/home/avneet/Desktop/qcad-2.0.5.0-1-community.src/qcadlib'
cd src && make
make[2]: Entering directory `/home/avneet/Desktop/qcad-2.0.5.0-1-community.src/qcadlib/src'
g++ -c -m64 -pipe -pedantic -O2 -Wall -W -fPIC -D_REENTRANT -DQT_WEBKIT -DRS_NO_COMPLEX_ENTITIES -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++-64 -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4 -I../include -I../../dxflib/include -I../../fparser/include -I../../qcadcmd/include -Imoc -o obj/rs_actioninterface.o actions/rs_actioninterface.cpp
In file included from ../include/rs_entity.h:33:0,
from ../include/rs_atomicentity.h:31,
from ../include/rs_arc.h:30,
from ../include/rs_entitycontainer.h:31,
from actions/rs_actioninterface.h:34,
from actions/rs_actioninterface.cpp:28:
../include/rs_dict.h:31:19: fatal error: qdict.h: No such file or directory
compilation terminated.
make[2]: *** [obj/rs_actioninterface.o] Error 1
make[2]: Leaving directory `/home/avneet/Desktop/qcad-2.0.5.0-1-community.src/qcadlib/src'
make[1]: *** [lib/libqcad.a] Error 2
make: *** [all] Error 2
Building qcadlib failed
avneet@avneet-Lenovo-G560:~/Desktop/qcad-2.0.5.0-1-community.src/scripts$ ./build_qcad.sh no_trans
Please help me to solve this error.
Avneet
Re: GETTING ERRORS WHILE COMPILING COMMUNITY EDITION
Post by Avneet » Thu Feb 28, 2013 8:27 am
Please tell me where i am wrong?
I am waiting for your reply
Re: Getting errors while compiling community edition
Post by andrew » Fri Mar 01, 2013 2:50 pm
The QCAD community edition (2.0) requires Qt 3.3.4.
See also notes at https://www.ribbonsoft.com/en/qcad-downloads-trial -> QCAD Community Edition.
Avneet
Post by Avneet » Fri Mar 01, 2013 5:16 pm
Please can you send me a link where i able to download " Qt package " completely??
Avneet
Post by Avneet » Sat Mar 02, 2013 10:52 am
I am getting same error again.
