... Edit more than one text element at a time
Postby ericsopa » Thu Sep 13, 2007 4:46 am
I can select multiple text elements, but how do I change the properties of all the text elements at once? So far I'm only able to select the "Edit Text" tool and click on each text element one at a time to change things like size. Which of course makes "Select All" seem useless.
This is probably just some mouse button, click, drag thing.
It seems like there should be a way to set element properties at the layer level, is this possible?
ericsopa
Re: ... Edit more than one text element at a time
Postby andrew » Thu Sep 13, 2007 7:31 am
ericsopa wrote:I can select multiple text elements, but how do I change the properties of all the text elements at once?
This is only possible with the Property Editor that was introduced in QCad 2.1.2.8. This widget is proprietary (from Trolltech) and therefore cannot be used in the community edition.
ericsopa wrote:So far I'm only able to select the "Edit Text" tool and click on each text element one at a time to change things like size. Which of course makes "Select All" seem useless.
Note that "Select All" makes sense in many other cases, for example if you want to move all, rotate all, delete all, ...
ericsopa wrote:This is probably just some mouse button, click, drag thing.
On the layer level you can only set color, line width and line style.
Return to QCAD Community 'How Do I' Questions
Who is online
Users browsing this forum: No registered users and 1 guest
