qcad not hatching
qcad not hatching
Postby edgewing » Mon Jun 18, 2007 12:10 pm
Hi All,
I have installed qcad on SUSE 10.0 and seem to be having some sort of issue in letting it know where the patterns are for the hatches.
I have set the correct path /usr/share/qcad/patterns in the settings but after I draw a rectangle and try to fill/hatch it, nothing appears to happen. I use the sequence exactly as in the manual. First, draw the rectangle, then hatch, select window, draw selection window so rectangle is selected, proceed to next menu using -> and then try to either solid fill or hatch. Neither of which work.
Also, the hatch patterns are displayed but I cannot get a preview of them.
What have I done wrong? :oops: :oops: Is there somewhere I've forgotten to set the correct path? apart from the application preference screen?
edgewing
Postby edgewing » Tue Jun 19, 2007 11:32 am
Please excuse the blathering idiot :oops: :oops: :oops: :oops: :oops: :oops: :oops:
I finally read the bit in the manual that said draft mode does not show hatches.
Mea culpa, mea culpa, mea maxima culpa
edgewing
Return to QCAD Community 'How Do I' Questions
Who is online
Users browsing this forum: No registered users and 3 guests
