How can I insert a block or just a line at a same distance along a path made of lines and arcs?
In this drawing:
there is a road, but how can I draw street-lamps with 20 meters of distance?
Thanks!!!!
How to repeat a block along lines and arcs?
You need to proceed for lines and arcs separately.
- For lines: use move-copy command.
- For arcs: you need to know the radius of the arc, then calculate the corresponding angle according to your distance (20 m). Say your radius is 40 m: the corresponding angle is
then use rotate command.
distance/radius = 0.5 rad
