Hi guys!
I use QCad on Debian Linux and the only issue i have is that the QCad interface starts in the old Linux interface and even if i change the QT settings and restart QCad the same old ugly interface.
I have QT3 and QT4 installed used by QT Linguist, this should be the problem?!
Thank you very much!
Anoying interface problem
